March 15, 2021 at 10:18 am
Vincenzodiba
SubscriberHello,
I simulated a simple battery pack composed of two cylindrical cells connected in series, performing the MSMD battery model with the ECM option. The battery rating voltages are 4.2, 3.6, 2.5 V for the max, typ and min respectively. I executed the "parameter estimation tool" with experimental data in order to fit the model parameters. Even if the simulation seems working, I obtained an unespected result for the positive voltage: since they are in series, I expeted a voltage range between 8.4 and 5 V, instead the result is the following.
March 16, 2021 at 4:43 pmwcao
Ansys EmployeeHello,nI wonder which version of Fluent you are using currently? nBesides, please try plotting the Phi- instead of Phi+ at the p-tab and see if that make sense. Thank you.nMarch 16, 2021 at 5:28 pmVincenzodiba
SubscriberI found out I should have selected Phi- in order to obtain the Voltage plot of the whole pack.nViewing 2 reply threads- You must be logged in to reply to this topic.
2706
2142
1355
1144
462
