Voltage Result not recognized in Mechanical
    • sehallsanchez
      Hello all,
      I am learning to use the Coupled Fields ACT extension's tools to do piezoelectric simulation and I am testing a simple setup where a cube piezoelectric body is subject to deformation and I want to measure the voltage generated. However, when I want to solve for the voltage, the program says that the VOLTdefined result is not recognized. It shows the following message:
      "Unable to create user defined result. VOLT is not a recognized result in: 59 = VOLT"
      Attached is an image of my current setup. Is this a problem with mechanical not recognizing my extension? If so, how do I make sure it does?
    • HuiLiu
      Hi
      Could you use Piezo & MEMS ACT instead? Also a good check is to see in your solver.out file what element types you have. You should have element type 226 or 227 if Piezo is included
    • sehallsanchez
      I checked the type of elements I am using and they seem to be of type Solid 186. How do I change them to be type 226 or 227? Thank you.
    • Sandeep Medikonda
      Please see this post
    • sehallsanchez
      Thank you for your help so far. I added into the command line the following:
      "et,matid,226"
      However I have the following errors in my Solver Information:
      *****  ANSYS SOLVE    COMMAND  *****
       *** WARNING ***                         CP =       0.391   TIME= 1506
       There are no degrees of freedom defined.
       Element shape checking is currently inactive.  Issue SHPP,ON or
       SHPP,WARN to reactivate, if desired.
       *** ERROR ***                           CP =       0.391   TIME= 1506
       SOLID226 element 1 must have a nonzero KEYOPT(1) value.
      Thank you.
    • Sandeep Medikonda
      Please read through the docs on SOLID226.
      You would have to specify KEYOPT(1) = 1001 for Piezoelectric or Electrostatic-Structural analysis.
      If you are not familiar with APDL, you might find this article helpful.
      How to access ANSYS ONLINE Help
    • HuiLiu
      You can use command object to change the element type and apply BCs loading etc, like Sandeep pointed out. A simpler way is to use the Piezo & MEMS ACT instead of coupled field ACT you have right now. I think the latter is no longer maintained, since a few versions back...
    • sehallsanchez
      Thank you so very much to both of you. I learned how to change to the solid type 226 but was still having a little bit of trouble. I finally switched to the Piezo & MEMS extension and not it is working fine.
    • HeMeng
      HI,I have the same problem?
      Do you solve it?
Viewing 8 reply threads
