Discovery Import
Discovery Import
Volume flow in Nm3/h
    • c.rabadan
      Hi, I have created Air in normal conditions at 0ºC and 1 atm pressure. If I create a monitor for the Volume flow, this is giving me the flow in m3/h but with the air in Normal conditions, can I assume that this flow is in Nm3/h? Thank you in advance,
    • Subashni Ravichandran
      Hello C. Rabadán
      The Volume flow, I believe, is measured at the final temperature and pressure of the fluid.
      Although, let me check with my team on this.
    • c.rabadan
      OK, I wait your comments. Thank you so much.
    • c.rabadan
      Hi Subashni,
      Could you check this matter with your team?
Viewing 3 reply threads
