volume fraction for mixture model?
    • kailash
      Hi. I am interested in getting the value of volume fraction in the mixture model. I see that variable for getting the Volume fraction for the VOF model is C_VOF(c,t). I would like to know what is the variable to use in mixture model. Is it the same?n
    • Surya Deb
      Hello, nWhat is the UDF that you want to use this macro in?nThe macro is still the same but you will need to fetch the correct thread for the phase.nYou can use THREAD_SUB_THREAD () macros if needed to fetch the thread of individual phases from the Super Mixture thread.nPlease look into the link below to get an idea on the advanced multiphase macros in Fluent.nnI hope this helps.nRegards,nSuryann
    • kailash
      I am going to use this under DEFINE_SOURCE macro. Thank you very much for the reply. I will look into the link you sent.nnRegards,nKailash R.n
