November 17, 2018 at 5:21 am
gowthamdada
Subscriberis necessary to mention air fraction in volume of fluid method?
i can enter mixture velocity. how its works when liquid and gas entering in mixture velocity of 0.1
November 18, 2018 at 3:05 pm
Karthik R
AdministratorHello,
In VOF, there can only be one phase - either liquid or vapor, entering or exiting from inlet and outlet boundary. You cannot specify a mixture of two phases at these inlet and outlet boundaries. Please share some more details about your problem so we can understand your modeling needs better.
Thank you.
Best Regards,
Karthik
November 18, 2018 at 3:52 pm
November 19, 2018 at 8:50 am
Keyur Kanade
Ansys EmployeeAs mentioned by Karthik, only one phase can enter. So you can split inlet into two parts and use one inlet for each phase if you want to give velocity to both phases. Then it is not necessary to patch. But patching is recommended. Please use patch as best practice. It would save a lot of time.
November 19, 2018 at 2:09 pm
gowthamdada
Subscribercan split the inlet two parts in fluet itself.
is there any chance without affecting the mesh?
if i gave two inlets VOF method will be good for futher simulation
November 19, 2018 at 5:06 pm
Ansys EmployeeYes, if you look at the Separate commands in Setting Up Domain. You'll need to create an adaption register (Mark) to tag the cells that you want to split. Note, this will split the existing mesh and does not add or remove cells.
The highlighted words are all the commands/menus you'll need: the Help guide will show you what to do with them.
2656
2120
1349
1118
461
