vorticity in CFD post
    • Luca Capitelli
      Hi everyone, I need the vorticity to show turbolence animation on a cylinder but it doesn't appear between the variables. I check step by step tutorials on yt and in cfd forums but I can't solve the problem. Can anyone help me?
      These are the steps I follow. Thank you all!
    • Keyur Kanade
    • Luca Capitelli
      Thank you very much! I follow the steps, now the vorticity appears but my result is strange because the turbulence is not as it should be for Re = 10000. This is the result after 277 seconds. Could it depend on the solution method? I used simple one with default options and simplec with all options at the second order.
    • Keyur Kanade
      It depends on your set up in Fluent. As this post was about CFD-Post, can you please open a new post on Fluent?
Viewing 3 reply threads
