September 1, 2022 at 6:51 am
lancer
SubscriberHello,
Recently I came across a fluent file but I cannot get the geometry of the fluent file. So that why I need help.
The situation its like this, I found a tubular geometry where there is a wall and wall-shadow adjacent to the cathode and anode. But the wall and wall-shadow is the electrolyte. Suppose there should be a zone condition for electrolyte but there is not. and Anode and Cathode are fluid zone but need to have a solid zone for it to have wall and wall-shadow boundary if I am not mistaken. I guess the interface between the anode and cathode are electrolyte but how can you make interface a solid zone?
Anyone can help?
Below are the picture associated with my problem:
September 5, 2022 at 4:28 am
Keyur Kanade
Ansys EmployeeIf I understand it correctly, please change interface type to 'wall' under boundary conditions panel.
Please go through help manual for more details
Keyur
September 5, 2022 at 5:53 am
lancer
SubscriberSo does this mean I need electrolyte part when designing the model in Geometry and Meshing before uploading into Fluent Solver?
September 5, 2022 at 7:05 am
Keyur Kanade
Ansys Employeeyes
September 5, 2022 at 7:10 am
lancer
SubscriberBut how did it not included in zone condition, I thought that each part created from geometry and meshing, it will appear in zone condition. But, electrolyte exist in the solver but not in zone condition?
September 5, 2022 at 7:12 am
Keyur Kanade
Ansys Employeewalls are boundaries and not cells. boundary zones are different and cell zones are different.
September 5, 2022 at 7:33 am
lancer
SubscriberI kinda partially get it. So the electrolytes are walls? But, how do you make solid electrolyte wall in between 2 fluid zone?
September 5, 2022 at 7:57 am
Keyur Kanade
Ansys EmployeeYou will need to have a solid body of electrolyte in SpaceClaim, mesh it in meshing and then move to solver to get cell zone for solid eletrolyte.
September 5, 2022 at 8:17 am
lancer
SubscriberExactly, if you want to have a wall-electrolyte and wall-electrolyte-shadow, you need to have a solid body electrolyte in the cell zone condition. But, the example I show, they do not. Do you know what I'm talking about?
September 5, 2022 at 8:21 am
Keyur Kanade
Ansys EmployeeYou will need to use share topology in SpaceClaim before going to meshing. Please check share topology posts on the forum.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2642
2110
1335
1112
461
