Wall Lubrication Force
    • PrantikDas
      How to implement wall lubrication force in my simulation as there is no tab in phase interaction for wall lubrication force in ANSYS FLUENT?
      Which model have you got switched on?
    • DrAmine
      That tab does only appear for Eulerian Multiphase Model.
    • PrantikDas
      I am using the below given models :-
      That's an older version of Fluent. You should see a "Phase Interaction" label in the tree under the phases.
    • PrantikDas
      considered solid-liquid two-phase flow
    • PrantikDas
      Is there any Fluent Console command to activate wall lubrication force?
    • DrAmine
      Does not make a sense fir granular flows.
Viewing 7 reply threads
