Wall Surface Reaction Problem with UDF
    • vinaychandrakar11
      Hello Everyone,
      I am trying to simulate the flow of gaseous mixture in the channel. walls of the channel are catalytic and wall surface reactions are happening. I wrote a UDF for surface reaction rate and successfully compiled and its showing in function hooks. geometry of problem is shown below.
    • vinaychandrakar11
      Can anyone help me with the above mentioned problem?
    • RK
      Can you please make sure that the UDF is compiled right? You also might want to check where the reaction mechanism is being pulled while solving. You can plot a contour of, say, species and check if it makes sense.
    • vinaychandrakar11
      Hi RK UDF is successfully compiled without any warnings and errors and its hooked properly, I defined the species in orders and reactions in the mixture template panel same as my UDF, but still not getting my reaction rate.
      I had given random rate exponent in mixture template panel (all is equal to 1), because I think it will take directly from the UDF. Is this correct ?
    • DaShuai_Chen
      hello´╝îhave you solved this problem yet´╝ƒ I urgently beg your help
Viewing 4 reply threads
