want to add water tank on the structure to check the behavior of the fluid
    • Suhailabbas
      i am doing harmonic analysis of a structure having time varying load (voltage),and i did it, now i want to add water tank on this structure to check the behavior of the fluid , this water tank does not have any inlet outlet velocity , that mean inlet and outlet are closed, but have a free surface, please suggest which analysis i will do?
    • Karthik R
      Administrator
      Hello You should be able to set up your problem as a Multiphase simulation in Ansys Fluent. You will need to use the System Coupling to transfer your loads from your Harmonic analysis to Ansys Fluent. I think you will apply these loads to the walls of your tank. This would be the pressure that would be applied to the Fluid, which will move the interface (which is estimated by, say, the VoF model).
      Please look into this link to find some tutorials on 'System Coupling'.
      Ansys Product Help
      Regarding setting up a VOF model, please see the following tutorial (#19 - using the VOF model) on our Ansys Help page.
      Fluent Tutorials (ansys.com)
      Files can be downloaded using the following link.
      Ansys Product Help
      Karthik
    • Suhailabbas
      hi
      but after doing harmonic analysis, i am not able to couple it with the ansys fluent using system coupling, what should i do now ?
    • Suhailabbas
      hi kremella
      how i can couple harmonic with fluent , can you please tell me ?
    • Sheldon Imaoka
      What behavior of the fluid are you interested in examining? Are you interested in looking at generated pressure (acoustic) waves from the structure? You mentioned no inlet/outlet, so if this is a water tank, what kind of behavior of the fluid are you hoping to investigate?
      If you are interested in acoustic waves in the water tank, you can perform a vibroacoustic analysis. In Mechanical, for example, this could be done with a "Harmonic Acoustic" system to define the fluid (acoustic) and structural portions.
      Regards Sheldon
    • Suhailabbas
      ok sorry i did not mention in the above query
      there is a free liquid surface and i wanna to check the waves generated in the surface
    • Suhailabbas
      i wanna see what will be the behavior of the free surface of water
    • Sheldon Imaoka
      In Mechanical, you can solve a vibroacoustic analysis (Harmonic Acoustic) and define a Free Surface object to accomplish what you are seeking.
      Regards Sheldon
    • Suhailabbas
      thank you so much
    • rahul_123
      did you solve that ? can you send your model. I need help.
Viewing 9 reply threads
