    • shraypandey18
      i was doing analysis of the fixture design, but when i mesh and solve i get the warning. what should i do if this error comes?
    • peteroznewman
      What units were you in when you solved?  Was it mm?
      Try solving with the units set to m.
    • shraypandey18
      it is in m
    • peteroznewman
      If you right click on that message, does it take you to the contact?
      How many contacts do you have?
    • shraypandey18
      I tried your mm method and realised that my assembly was in mm and my Ansys units was in m so changed the units in Ansys from m to mm and it worked and the error went.
Viewing 4 reply threads
