Warning after Merging Nodes in ansys apdl.
    • Oimpa
      I've created a model in Ansys apdl, I want to linear elastic analyse it.
      The image below shows the model after meshing.
      No warning will be given when meshing.
      But when I want to merge the nodes, the following warning is given.
      After this, the problem can not be solved anymore.
      How to solve this problem?
    • Sandeep Medikonda
      The mesh is bad, the only recommendation I can give is to refine or make it consistent i.e., avoid the big changes in the aspect ratios of these elements.
