February 15, 2023 at 5:12 pm
dharmarathnes
SubscriberHi I am using Ansys after a long time. I run ANSYS Flueng V2022R1 on RedHat Linux 8.1 system. When fluent is starting up I get the following warning in the console area.
Warning:
Software rasterizer found, hardware acceleration will be disabled.
In the absence of hardware-accelerated drivers, the performance of all graphics operations will be severely affected. Make sure you have a supported graphics card, latest graphics driver, and a supported remote visualization tool with direct server-side rendering enabled. If you feel your system meets these requirements, try forcing the accelerated driver by using the command line flag (-driver
) or setting the HOOPS_PICTURE environment variable. Refer to the documentation for more details. Does anyone know what the reason for this warning? what should I do to get rid of this?
February 17, 2023 at 1:12 pm
Essence
Ansys EmployeeHello,
Can you share the screenshot of the warning?
3778
2587
1831
1244
598
