October 14, 2018 at 2:07 pm
fa-ri
hello
I'm working on flow past a 4-rotor drone.
I meshed the geometry using curvature size function and I have a tetrahedrons mesh method.
I initialized the simulation and used mesh motion for each rotating volume.
how can I fix this warning?
I would be really grateful if anyone could help me
Thank you
With regards
October 15, 2018 at 4:21 am
Keyur Kanade
Ansys EmployeeDid you check the mesh before starting simulation? Did it pass the check?
When you created mesh, what was the quality. Please check orthogonal quality of the mesh. The min ortho must be more than 0.1.
Also did you use non conformal interface of sliding mesh? Did you define the axis of rotation correctly in Fluent?
Please have a look at following for sliding mesh.
Keyur
October 15, 2018 at 4:26 am
Keyur Kanade
Ansys EmployeeYou may also want to look at following post.
https://forum.ansys.com/forums/topic/how-can-i-locate-and-fix-left-handed-cel/
Keyur
October 21, 2018 at 5:08 pm
fa-ri
SubscriberThank you for your response.
I checked the orthogonal quality of the mesh. The min was 0.2004.and its non-conformal.
I checked the rotating axis.
during of flowing the tutorial I see the following errors:
I ignored the note and saw this one during processing
how can I fix this problem?
Thank you
With regards
October 22, 2018 at 6:20 am
Keyur Kanade
Ansys EmployeeHello,
You can ignore the first note of creating empty surfaces.
For second error - can you please check if you can process it using serial mode first.
Are you using any UDF? Are there any solid zone? Please cross check your boundary conditions. Please check boundary types.
Keyur
2656
2120
1347
1118
461
