Warning in DPM
    • pavankonchada123
      Hi Ansys Team,
      Can you please through some light on the below warning
      Warning: injection: injection-0: zero particle mass, cannot conserve injection mass flow rate
      Check the injection. There was a change a few versions back so you need a small mass even if you don't have interaction with continuous phase switched on.  1e-20 kg/s is sufficient.
