warning in mesh solution
    • Beni
      how to ignore warning on this mesh if I will use MRF
    • DrAmine
      Meshing created stair stepping cells at some locations. Fluent does not like this kind of mesh but this us only a warning. Check global mesh metrics in Fluent and then improve your mesh or work with it if the quality us acceptable.
    • Beni
      thank you Mr. Abenhadj for your suggestion, I will try it first
