warning meg popping up- Ls Dyna
    • dorischen
    • Erik Kostson
      Can you try to do a simple model with WB-LS-Dyna system in Workbench, mesh it and look at the meshmetric graph?
      Also does this happen for any other systems say a Static one?
    • Vincent Chen
      I have the same issue. It happens to the static as well.
    • Erik Kostson
      So if you press No on the Script error (msg) can you continue using Mechanical and carry out an analysis?
Viewing 3 reply threads
