March 29, 2022 at 3:36 am
lkl
SubscriberHi, I'm new to Ansys. I have two warning messages after I input my spring connection (body to ground) to the rail profile and solve it.
March 29, 2022 at 1:12 pmRahul Kumbhar
Ansys EmployeeHiYou can find more information about this warning in Ansys Help at this link.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/wb_sim/ds_one_or_more_mpc.html
As the second error pointed out, the shared face/edge in in Spring definition can cause the problem. However this is just warning. So you should verify the results if those are okay. Then you can ignore it.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4502
2963
1449
1322
