Ansys Products
Ansys Products
Warning upon inputting .igs file into ANSYS Mechanical APDL
    • jheb172
      After I import a .igs file created in Autodesk Inventor into ANSYS Mechanical APDL, I get a warning that says "Discontinuous area set for volume". After closing the warning, the import of the model seems to have gone fine. Should I just disregard this warning? What does it mean?
    • Chandra Sekaran
      You might just have areas - no volume. Do a VLIST or VPLOT to make sure you can plot the volume.
