3D Design
3D Design
Warning when opening the crank file in ansys 18.2
    • haneonf
      I am participating in the CornellX course in edX. However, I could not open the crank.wbpz file in ansys 18.2. Attached is the warning message I got.
      I need help.
    • peteroznewman
      If you double click on Model, Mechanical will open. Press F7 which is the fit view key. If you see the geometry, you can proceed.
    • haneonf
      Thanks a lot. I was able to see the geometry even without using the F7 key. After I double clicked the file and open mechanical, I then double clicked geometry cell and the file opened.
      Your response is highly appreciated
    • peteroznewman
      Good to hear it worked. Please click the Is Solution link below the post with the answer to your question to close this discussion, and click Like to show your appreciation.
Viewing 3 reply threads
