Preprocessing
Preprocessing
Watertight Geometry
    • chebusann
      I usually use watertight geometry in ANSYS Fluent. So, when starting Fluent: in start Menu I select options as default, and when Fluent open I can not see Watertight geometry anymore.
      Anyone knows how can I see this option again?
      Thanks.
    • Karthik R
      Administrator
      You have to change to the meshing mode to see this option.
      Thanks.
    • chebusann
      Thanks Kremella, I found this option in Preferences. I cannot select "Meshing options" because I cannot select "OK". Do I have to do other thing?
      Thanks
    • peteroznewman
      You have to provide a path to the Temporary files folder.
    • Keyur Kanade
      Please specify a path for temp files.
      It is shown in yellow color in the panel.
      Keyur
Viewing 4 reply threads
