TAGGED: material-properties, structural, wave-propagation
February 18, 2023 at 1:13 am
larito
SubscriberHello I am trying to create a wave that propagates through the pipe when I do 2-way coupling with Fluent. I have set a fluid geometry enternal pipe+ the volume in the back and set the external geometry as the solid. I have chosen water as the fluid and Plastic Pi as the solid. I have set the pipe as a fixed support and run the simulation for 20 seconds.
In the results I see a deformation that decreases linearly for a few mm until it vanishes. I played a bit with Young Modulus and now I will change the pressure inlet which is a UDF set to create pulse flow with 1000 Pa every other second.
I am not very familiar with structrular and my current suspicion is that the pressure is not enough at this point to create such behavior. Do you have any advice on what needs to be changed in order to achieve a wave propagation?
Thank you
February 20, 2023 at 12:42 pm
Ashish Khemka
Ansys EmployeeHi,
Please see if the following link helps:
Reporting an error in Anisotropic Elasticity Matrix calculation (ansys.com)
Ashish Khemka
February 20, 2023 at 6:35 pm
larito
SubscriberHello Ashish,
Unfortunatelly it does not help me but thank you very much for your reply. I am not clear on how to imitate pressure wave propagation in Ansys that is all. If you have any advice on that I would really appreciate it.
Best regards
February 21, 2023 at 9:26 am
Ashish Khemka
Ansys EmployeeHi,
I shared the wrong link and I apologize for the same. Please see if the following link helps:
Generating Pressure Wave (ansys.com)
Ashish Khemka
February 21, 2023 at 11:49 pm
larito
SubscriberThank you once again. Do you happen to know where I can find the Expicit Dynamics documentation?
Thank you
EDIT: I found a bunch of stuff in Ansys Learning hub
February 22, 2023 at 1:21 am
larito
SubscriberHello again,
I was wondering if you have a tutorial in mind because I am going through infinite amount of pages and honestly I am getting more confused. I want to see an example to understand what is happening.
Best regards
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
3926
2641
1861
1272
610
