January 3, 2023 at 12:10 pm
zahra mansouri
Subscriberi am working on waveguide simulation in fdtd and mode solution lumerical. i have a cylinderical waveguide. with mode solution i get the neff and so i have propagation lenght of that. then i design the waveguide in fdtd solution and i use mode source for exciting a special mode that i calculateed propagation lenght for it. but here i cant see the propagation lenght that i calculated in previous step.
my designed propagation lenght is 2 micron. in fdtd i draw a 4micron lenght waveguide and i excite it with only one mode but i cant see attenuation of wave.
can anyone help me?
January 3, 2023 at 7:41 pm
Guilin Sun
Ansys EmployeeThis is a duplciated post. Please refer https://forum.ansys.com/forums/topic/waveguide-simulation-in-fdtd-solution/#post-245428
- Error on Lumerical device
2630
2104
1329
1110
461
