October 9, 2018 at 9:53 pm
soloviev
SubscriberHello,
I am simulating the spray generation produced by hurricanes at the air-sea interface on a wavy sea surface. I know it is possible to create a water layer with a wavy surface representative of ocean waves by using the Open-Channel Wavy Boundary Condition with an inlet and an outlet. If I set up the Wave BC in this fashion, is there any way to then set the velocity magnitude of the air (wind) at the top of the domain to have some constant value (e.g., 50 m/s), while the velocity would be zero in the water portion of the domain?
Thank you,
Alex
October 10, 2018 at 8:41 am
Ansys EmployeeIf you set two surfaces on the inlet plane:
- lower one high enough to include the waves, set using open channel
- upper one set with an air velocity
You may see some odd effects near the inlet as the wave trough and air inlet don't quite tie up but the remainder should work, and it should sort itself out fairly quickly. Try it in 2d as it should work/fail fairly rapidly.
October 10, 2018 at 8:35 pm
soloviev
SubscriberI think this will solve my problem. Thank you for your help.
Alex
2588
2080
1315
1108
459
