Ways to generate mesh on a thin air gap?
    • ClarkJ
      Hi,I’m trying to mesh a thin air gap,but it has a lage area.Now if i want to speed up the progress of meshing,i will get a really bad quality.like this picture..and only two layers.
      What does the rest of the geometry look like? n
    • Keyur Kanade
      Make sure you have same number of edges on source and target faces. ne.g. if source face has 6 edges and target face has 7 edges then such problem may come in. nAlso check sizing functions you have defined on this and adjacent geometry. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
    • ClarkJ
      Hi Keyur,nActually,I did not use a sweep method,i use Multizone instead.Will it be better if i use sweep?nthank you for your reply!n
Viewing 3 reply threads
