December 4, 2019 at 2:55 pm
Autonewbie
SubscriberHi I am trying to select the elements as attached. When I select the elements by Box Selection, the mesh nodes selected are on surfaces only. How do I all the elements without using location? Thanks!
December 4, 2019 at 3:22 pm
December 4, 2019 at 3:28 pm
Autonewbie
SubscriberI was trying to insert a picture but there was an error this time. Anyway, thank you for helping to insert the picture!
Access Denied
You don't have permission to access "http://studentcommunity.ansys.com/topic/editposttopic/f14a4a9e-48a1-4ad2-a94c-ab1900f5f198/" on this server.
Reference #18.a1a50517.1575473244.26b04784
December 4, 2019 at 8:22 pm
SubscriberIf you slice that end of the body from the solid, you will have two bodies. You can use Shared Topology to reconnect them in the mesh and then you can easily select one body to get all the elements in it.
3383
2471
1310
1022
