Weird bending in tensile test sample
    • jinglun
      I am simulating the tensile test of a non-standard geometry dogbone sample.
    • peteroznewman
      It looks like thickness is the Y axis, not the Z axis, so the bending of the end is in the Y direction, not Z.nThe right edge (X displacement of 0.28 mm) should also have a Y displacement of 0.0 to prevent this bending.n
    • jinglun
      Thank you sir, that solved the problem!n
