May 17, 2023 at 4:08 pm
May 17, 2023 at 6:05 pm
NickFL
SubscriberHave a look at your geometry there. One possible solution if you don't want to go back to DesignModeler / SpaceClaim is to use Virtual Topology to merge faces. My expectation is there are a couple of short edges or hard points there that you will want to remove. -
May 17, 2023 at 6:21 pm
Alina Larin
Subscriber-
May 18, 2023 at 11:18 am
NickFL
SubscriberThere must be a folded face or hard points or something there. Otherwise, the Mesher would have nothing to seed. Another approach would be to use the Patch Independent tet mesh method. Are you familiar? Basically this will mesh the volume and then projects it to the surfaces. If you adjust the settings a bit, you should be able to have this ignore this thin line/point/whatever it is. To use it, add a Method with Type-> Tetrahedrons and then change the Algorithm from Patch Conforming to Patch Independent.
May 18, 2023 at 12:51 pm
Alina Larin
SubscriberThnk you very much. Yes I tried to use patch independent meshing, but every time I am trying the computer get stucked. I have returned to spaceclaim and splitted this face multiple times. And it helped!
May 18, 2023 at 8:57 am
Ansys EmployeeHave a look for hard edges and/or a kink in the surface. The mesh thinks there is something there that needs resolving.
May 18, 2023 at 12:53 pm
Alina Larin
SubscriberThank you you Rob. The face has indeed number of kinks. So I have splitted the face in Spaceclaim and it helped!
May 18, 2023 at 1:07 pm
Ansys EmployeeOK. If you're using Fluent also see if the geometry does the same in Fluent Meshing. Where did the geometry come from? It looks vaguely organic.
May 18, 2023 at 1:25 pm
Alina Larin
SubscriberIt is CT scan of some vein. Originally the geometry was in STL format and I performed reverse engineering in SpaceCaim using Auto Skin.
May 18, 2023 at 1:28 pm
NickFL
SubscriberYes STL sometimes will have floating triangles with incorrect outward pointing normals. They often require a lot of time to get cleaned up, although the aforementioned SpaceClaim makes it much better than it used to be.
May 18, 2023 at 2:35 pm
Ansys EmployeeIt's sometimes better to talk to whoever did the segmentation of the MRI scan if you can. The two packages/developers that I'm aware of have surface remeshing options that may make life a little easier.
https://www.ansys.com/partner-ecosystem/technology-partners/materialise
https://www.ansys.com/partner-ecosystem/technology-partners/synopsys
May 18, 2023 at 2:42 pm
Alina Larin
SubscriberThank you very much for your help!
5386
3375
2471
1310
1022
