Weird wind direction
    • anhvu lee
      I'm testing the wind direction in the Steady state since a lot of issue in Transient mode. Still, the result in Wind velocity made me so confused about my set up or anything else (please see the "red mark" in my attachment).
      The inlet for the North and West side is the same with the expected 45 degree for the input
      The outlet for the east and south, with the "Normal to boundary" for the backflow direction.
      Please help me to check and give me some suggestions for this issue.
      What did you set for fluid density?
      • anhvu lee
        I set it as default recently, with 1.225 kg/m3
      It should blow through OK then as the blockage isn't going to have much of an effect on the flow.  Plot velocity contours on a few horizontal planes and post the results.
