October 23, 2018 at 3:13 pm
sameerfares
SubscriberHi All,
What are the material properties needed to simulate the weld behavior? This is electrode 70 that is used for the filler material. Weld material has a yield strength of 57000 psi and ultimate tensile strength of 70,000 psi.
Thanks,
Sam
October 23, 2018 at 3:15 pm
Keyur Kanade
Ansys EmployeeMoving to structural mechanics category for better response.
Keyur
October 23, 2018 at 3:20 pm
Sandeep Medikonda
Ansys EmployeeYou can either use joints or contact formulations as discussed in this example of the Technology Demonstration guide.
Sandeep -
October 23, 2018 at 3:26 pm
sameerfares
SubscriberI am asking about the Weld material physical properties that i need to put inside the Engineering Data A2.
Thanks,
Sam
October 23, 2018 at 3:34 pm
Sandeep Medikonda
Ansys EmployeeProperties you want to use are dependent on the material models you are using and the analysis type you are carrying out.
See this example for sample material properties. You can start with Elastic and use a BISO plastic Material model.
Sandeep
2088
1317
1108
459
