August 12, 2019 at 7:18 am
RZIlla
SubscriberHi all,
I am creating a 3-D model consisting of various pipes of different diameters and thickness. I model it in SolidWorks, and on the dimensions I would like to parameterize, I add DS_name on the dimension. This then is imported into Ansys Design Modeler, and then I can easily parameterize the model and run multiple simulations. But now I want to simulate with varying pipe diameters/thicknesses. Is there an option where I can import different pipe diameters into ANSYS or tell SolidWorks that all Pipe diameters also are a parameter that can be modified?
Thanks all.
August 12, 2019 at 5:02 pm
SubscriberIt seems you have done the required steps to create parameters. Did you click in the box next to the DS_name to turn them into Parameters so you get a Parametric Set in Workbench?
Please reply and insert some images into your post.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1349
1118
461
