November 30, 2020 at 4:19 pm
zulkarnainzakri
SubscriberDecember 10, 2020 at 9:06 pmDave Looman
Ansys EmployeeTo solve a rolling object it's necessary to limit the step size so the wheel doesn't rotate more that one or two degrees per step. nSound is a wave phenomenon so an acoustic analysis is usually harmonic or in rare cases transient. nIt's not obvious that a slow rolling wheel would create very much sound, but hypothetically the systems required are a transient structural analysis (transient so that the surface has a velocity to create waves) followed by a transient acoustic analysis. Workbench doesn't currently support transient acoustic analysis so a transient acoustic analysis would need to be done with APDL commands. nTo scope out the potential difficulties of the proposed analysis it is recommended to do a harmonic-acoustic analysis on a small plate model. This analysis type is supported in Workbench. The air elements for the acoustic domain should be no more than around the wavelength of interest divided by 10. So for example, if you are interested in audible sound of 5000 hz in air, the wavelength would be (343 m/sec)/5000 hz = .07 meters and the element size should be no larger than .07/10 = .007 m or 7 mm. This element size will limit how large the air domain is.nDecember 21, 2020 at 8:39 amzulkarnainzakri
Subscriberso i just need to analyse directly using the harmonic acoustic analysis ??? or there should be a primary analysis setting followed by the harmonic acoustic analysis....for example transient structural-harmonic acoustic analysis ???nViewing 2 reply threads- The topic ‘what analysis system that i need to use to obtain a sound pressure of moving wheel along the rail?’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3151
1680
1470
