TAGGED: ansys-mechanical, ansys-student, static-structural
May 10, 2022 at 9:11 pm
ZGL1
SubscriberWhenever I attempt to perform a static structural analysis of a model with more than a single component, it cannot converge to a solution. I think this must have something to do with the contact conditions being applied inappropriately, as there are never issues for a single solid body. I have two bodies as a single part, with a frictional contact specified.
May 10, 2022 at 11:33 pmpeteroznewman
SubscriberPlease insert images into your reply. Show the geometry, the supports, the loads and the contact definitions. Show the Analysis Settings.
May 16, 2022 at 10:58 amAniket
Ansys EmployeeThanks Peter! in addition to these, also check the error messages in solver output and try searching them on the forum to see if you find any useful solutions!
-Aniket
- A solver pivot warning or error has been detected
8700
4658
3151
1672
1446
