March 26, 2022 at 7:32 am
El_Manguangua
SubscriberI've been doing hundreds of face splittings in Design Modeler, and when I opened my model in Ansys mechanical, this dark-gray arrows appear (that do not belong to my model).
I'm attaching an image:
March 28, 2022 at 1:00 pmViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
7742
4502
2963
1449
1322
