What causes the following Warning message to be issued: “material XXX has a crack softening property
October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeAn Explicit Dynamics system requires both a crack softening property and a failure model. The failure model is required to initiate a crack. The crack softening property is required to propagate the crack. The material failure model is defined in Engineering Data.
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- What is cause of error: display time for result item greater than the step end time?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
Top Contributors
2630
2104
1327
1110
461
Top Rated Tags
