February 25, 2022 at 6:37 am
rahulb
SubscriberDoes Ls-Dyna - workbench support: MAT59, MAT 161, and MAT 162.
need to use solid elements for composite modeling with failure criteria. Want to know what material models are supported with ls-Dyna workbench.
February 25, 2022 at 3:55 pmRam Gopisetti
Ansys Employeeyou can use the commands to use material models which do not offer direct support. but for post processing and access history variables you may want to switch to prepost. for support of material check the link in description.
cheers Ram
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1279
1096
459
