what contact should I use
    • Andi Ko
      so these two bodies are not contacted yet in the initial state. I will apply displacement to the grey plate in x direction so the grey plate will hit the other body.
    • peteroznewman
      Use Frictional Contact. Edit the Pinball Radius and type in a distance of 4 mm to make sure the contact is detected as Near Open.  You can check that by inserting a Contact Tool under the Connections folder and Generating the Initial Contact Status.
      • Andi Ko
        thank you, I will try it
