March 11, 2022 at 9:24 pm
kymani_Brown
SubscriberMarch 11, 2022 at 9:24 pmkymani_Brown
SubscriberThis is a for a steady-state analysis
March 14, 2022 at 9:44 amRob
Ansys EmployeeAssuming the boundary values are sensible & finite, check what's holding the lump of stuff down. In Mechanical you need to stop things floating away. and will be able to explain properly - I support CFD solvers and we don't have this problem!
March 14, 2022 at 10:55 amAniket
Ansys EmployeeKindly check the solver output file, and search for the errors in there, once you get the errors, search those here on forum, and most likely you will get some way forward.
As the error states, the loads are excessive or supports are insufficient.
To quickly check the model, do a Modal analysis with all the supports that are being used in Structural analysis, and see if you see any rigid body modes.
-Aniket
2616
2098
1323
1110
461
