What does ‘An unknown error occurred during solution. Check the Solver Output on the Solution’ mean
    • phanicmsf
      What doe the error messages mean in ansys solution information.?
      I am able to solve the problem setup using Structural steel material for both geometries. But when I applied different materials Sic_Pores and Sic_Sic for each geometry I got the fallowing error.
    • Ashish Khemka
      It looks that the element is inverting due to the thermal strain. Can you check the CTE values and temperature change due to thermal condition, if it can cause element inversion?
      See if turning on the large deflections helps.
      Regards Ashish Khemka
    • Gary Stofan
      In the Solution setting, try Large Deflection = ON
      You could also try setting Auto Time Stepping to "On, then
      initial 25
      minimum 10
      maximum 1000
    • phanicmsf
      Thank you and for your explanation.
      For this question the answer from helped me to ovewrcome the error in my model.
      I am sharing the link for this answer.
      https://forum.ansys.com/discussion/comment/146820#Comment_146820
Viewing 3 reply threads
