March 10, 2022 at 7:19 pm
shk1048
SubscriberI have observed that increasing ISOLEVEL removes more amount of material. What does it actually mean and how it can be helpful?
March 11, 2022 at 8:19 amImtiaz Gandikota
Ansys Employeeiso-surface plot is just for post processing, LS-TaSC is not actually removing material based on iso-level value. It just shows which areas of the model has the material based on user specified iso-level.
For example, if you select 0.3 as the iso-level, ls-tasc simply shows all the elements in the model with relative density of 0.3 and above, that is all elements with relative density between 0.3 to 1.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2564
2080
1297
1106
459
