What does it mean by ‘Warning: zone of type interior found between different solids!’?
    • Donghyun Yim
      When I initialize the solution on fluent solve, the following message appears.
      Material of cell zone 14 is sus, while material of cell zone 13 is polymide.
      This will adversely affect the solution.
      It is recommended that you fix this issue via the TUI command
      /mesh/modify-zones/slit-interior-between-diff-solids
      Unless I enter the above command it diverges, but when I enter that command it converges.
      I got the final solution, but I am curious of why that warning appeared.
      Thanks,
      Donghyun
    • Keyur Kanade
      'interior' is nothing but the interior cells. for any boundary usually we have 'wall' type. so it it is 'interior' then solver will treat as 'interior' rather than 'wall'.
      if this helps you, please mark this post as 'is solution' to help others on forum.
    • Donghyun Yim
      So that warning message implies the absence of wall between different interiors (or solids), and that command splits them.
      If so, do I need to modify mesh before solve in order to prevent that warning?
      Thanks,
      Donghyun
    • Keyur Kanade
      no need to modify mesh.
      select face between two solids in meshing and give named selection.
      if you already have different named selection for this then please select this named selection in fluent and change its type to wall.
    • Donghyun Yim
      If the type of face between two faces is set to be wall, no thermal energy exchange or uds exchange occurs across the wall. (as I understood)
      So its type needs to be 'interface', not 'wall', doesn't it?
      Thank for your kind reply,
      Donghyun
    • Keyur Kanade
      you can set it as interface depending your configuration.
Viewing 5 reply threads
