What does it mean when # of contact elements in contact is reported as “-2” under Solution Tracker?
    • John Doyle
      The Solution Tracker in WB-Mechanical is using the NLHIST,,, command.
      From the MAPDL Commands Manual, you can find the following information on the command 'NLHIST,,,'
Viewing 0 reply threads
