November 11, 2019 at 10:48 am
mechguy1
SubscriberI am trying to find the power of vertical axis wind turbine. I have setup a problem as below.
tansient K-omega SST model
inlet velocity is 10m/s.
Rotor velocity is 200rpm I checked the frame motion box.
Rotor rotates around Z axis.
all other settings are left default.
The problem here is 5 blade design should have higher torque values as per the general physics.
I have attached the image of my torque results. Thank you in advance.
November 11, 2019 at 11:10 am
DrAmine
Ansys EmployeeCheck the CFX tutorial which explains why you should consider the absolute value. Torque you get is what the Fluids exert. But you provide power to rotate the impeller.
5364
3363
2471
1310
1018
