May 16, 2022 at 5:51 am
SAGAR_IITB
Subscriberwhat is " .gst" file??
I was working on explicit dynamics, the calculations were running ond 14 May at 1630 with 99.5% completion and job remaining time was shown as to be close to 1 to 2 hour. When I came back after one day I found the PC Shutdown. I am not able to recover the same. When I checked up the dp0 folder, I found one Autodyne file saved for 14 May at 1902 hrs and one ".gst" file which is 224 MB and ".sum" file of 4GB also saved at 1902 H on 14 May. Can I retrieve my lost file from this???
May 16, 2022 at 6:34 amVinayak Vipradas
Could you check if the following post helps?
Tutorial for files recovery ÔÇö Ansys Learning Forum
Regards Vinayak
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
May 16, 2022 at 6:52 amMay 16, 2022 at 7:02 amViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- Explicit dynamics ERRORS
- turning simulation
- explicit dynamics
- Monte Carlo Simulation
- Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.”
8786
4658
3151
1678
1468
