What is “Mesh from Positive/Negative Side” for Force Reaction using Construction Surface?
    • SaiD
      What is Mesh from Positive/Negative Side for Force Reaction using Construction Surface?n
    • Daniel Shaw
      It is based on Coordinate System (CS) used to create the Construction Surface. When a local CS is created, a Construction Surface is created along the XY plane of that CS. A Force Reaction probe can be placed using the Location Method "Surface" with the required Construction Surface selected from the drop-down list. Mesh from Positive Side refers to the positive Z direction of the local CS used to create the Construction Surface and Mesh from Negative Side refers to the negative Z direction.n
