July 31, 2020 at 1:45 pm
Keyur Kanade
Ansys EmployeeWhat is tensile strength of a material? How is it calculated?
May 21, 2021 at 12:44 pm
David Mercier
Ansys Employee.
To learn more about such mechanical properties, have a look into the Learn resource of the Ansys Granta EduPack software or lecture units in Ansys Education Resources:
http://support.grantadesign.com/resources/grantaedupack/2021R1/learn/
https://www.ansys.com/academic/educators/education-resources/lecture-stresses-strains-discovery
- What is the difference between internal and external flows?
- How do you define specific gravity? What is its significance???
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- The level of water inside the straw was higher than the level of water in the beaker
- How to gain research experience?
- What is the surface tension of a fluid?
- Whats the difference between sensible heat and latent heat?
- Cell Counting?
- Why does the total sum of forces acting on a system always have to be equal to zero?
- Why ice floats on water
2616
2098
1321
1108
461
