July 31, 2020 at 1:43 pm
prajput
Ansys EmployeeWhat is the amplitude of a wave? How is it different from frequency?
Keyur Kanade
Ansys EmployeeHi @prajput ! The maximum displacement of the particles from their equilibrium position is known as the amplitude, while frequency is the number of complete vibration cycles a particle completes in a unit time. Hope this is helpful.
July 31, 2020 at 1:44 pm
Karthik R
AdministratorIn case of sound waves, amplitude is associated with the loudness of the sound, while frequency determines the pitch of the sound.
Keyur Kanade
Ansys EmployeeA simple example to add to the previous answer is the guitar. When you strum a different string, the pitch of the sound produced changes (i.e. frequency changes) but the loudness is approximately the same (i.e. same amplitude). But when you connect the guitar to an amplifier, the loudness or volume increases (i.e. amplitude of the sound wave increases).
Viewing 3 reply threads
Trending discussions
- What is the difference between internal and external flows?
- How do you define specific gravity? What is its significance???
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- The level of water inside the straw was higher than the level of water in the beaker
- How to gain research experience?
- What is the surface tension of a fluid?
- Whats the difference between sensible heat and latent heat?
- Cell Counting?
- Why does the total sum of forces acting on a system always have to be equal to zero?
- Why ice floats on water
Top Contributors
2616
2098
1321
1108
461
Top Rated Tags
