March 23, 2021 at 5:39 am
batu16
SubscriberHello I want to figure out this horn's magnification ratio by doing modal and harmonic response analysis
here is what I got so far
March 23, 2021 at 1:33 pmAshish Khemka
Ansys EmployeeHi Array ,nnPlease see if these external links are of any help to you:nnArraynnhttps://ijaers.com/uploads/issue_files/15-IJAERS-JUN-2018-4-ExperimentalDesign.pdfRegards,nAshish KhemkanMarch 24, 2021 at 5:25 ambatu16
SubscriberThanks for response, I'v got what I needed.nI needed to give amplitude to horn at the rear end. So I found that first I need to insert fixed support for the modal analysis and then for the Harmonic response, insert a displacement, select base excitation and insert the amlitude that I need.nViewing 2 reply threads- You must be logged in to reply to this topic.
2656
2120
1345
1118
461
