Photonics
Photonics
What is the best way to introduce Borophene into the software?
    • Ashenone
    • Guilin Sun
      Hi Ashenone, thank you for posting this question. Before preceding to details, may I know what software are you referring ?
    • Ashenone
      Lumerical
    • Guilin Sun
      Lumerical has 2D thin sheet and 3D conductive material models: Standard optical conductivity material models in FDTD and MODE
      If the material is very thin, you can directly use the 2D thin sheet model, and the geometry is a thin sheet without thickness. 3D model actually converts it into permittivity. You may need to import it as dispersive material with anisotropy: Creating new sampled data materials in FDTD
Viewing 3 reply threads
