January 25, 2022 at 10:00 am
Abdul_4
SubscriberGood morning,
I am working on floating bodies using ANSYS AQWA and hydrostatic part been solved in free floating condition. To check the floating conditions and buoyancy force which volumetric displacement should I consider?
Thank you.
January 28, 2022 at 2:21 pmMike Pettit
Ansys EmployeeThe actual volumetric displacement is the fluid displacement of the structure calculated by Aqwa, based on the diffracting surface mesh and any line bodies. The equivalent volumetric displacement is the total mass of the structure divided by the water density. These two values will be equal if the structure is in hydrostatic equilibrium.
Cheers, Mike
February 1, 2022 at 6:02 amAbdul_4
SubscriberThank you for the response Mike.
3744
2573
1799
1236
594
